Old 09-14-2025, 05:06 AM
jbtech's Avatar
jbtech jbtech is offline
Default Stewart Warner Greenline 8000rpm Pedestal Tach 970B Modern Internals
This is a very nice, freshly modernized, 970B Stewart Warner 8000rpm Pedestal Tachometer gauge.
This gauge has a very nice unrestored case I believe is driver/unrestored quality but I believe the case could be polished to show quality.
This tach has modern internals including an adjustable potentiometer in which you can fine tune the accuracy to your ignition with a simple small flathead screwdriver.
The tach is setup for 8cylinder 12 volt systems and will work with both modern tach output signals and traditional points style systems that use the negative coil side for the trigger wire.
The tach is a very simple 4 wire setup with a separate light circuit included.
Red (Ignition Hot), Black (Ground), Green (Trigger), White (Light).
This is an excellent option plug and play tach for your unrestored ride. These tachs were used in many of the 427 conversion/copo cars as an option.
Price includes free US insured shipping to paid members.
Thank You,
Jose
Jose Betancourt
67 Camaro L78
Attachments - The Supercar Registry 20250913_181420.jpg 20250913_181352.jpg 20250913_181337.jpg 20250913_181324.jpg
