Old 09-05-2025, 10:10 PM
my70454ss my70454ss is offline
Default 69 ONLY Camaro Chevelle Nova 396 427 Z28 L78 L89 COPO ZL1 Motor mount hardware kit an
Hi SYC,
This one year only setup for high performance Small and big blocks was used exclusively in '69 for Camaros Chevelle's, novas, Impalas etc.
No one has correct original hardware available.
There are two different lengths bolts that attach the motor mounts to the blocks, the longer bolts attach the mounts that uses the spacer on the bolt and has a special lock plate that attaches under the mounts. The shorter bolts go on the other side without the special plate. There are also two different length bolts, a spacer, a large thick flat washer and two lock washers.
These setups are extremely hard to find.
1969 Fathom Green Yenko Camaro 4-Speed
1969 Garnet Red RS/Z28 Crossram JL8 4-speed ( Under Restoration )
