Old 09-02-2025, 06:17 PM
kenbrogan kenbrogan is offline
Default 1966 L72 427 Biscayne questions
I recently purchased a very nice 1966 Biscayne that is suspected to be an L72, The car has all of the date correct component's with matching casting numbers that would represent it to be a real L72. This includes the engine block, heads, bell housing, intake, carb, transmission, tail shaft housing, starter, alternator, rear end housing, along with radio delete, heater delete, 7k tach and more.
My only concerns are that the VIN plate in the driver door pilar and the protecto plate have 15311 yet the cowl tag uses the 15411. I have researched and found that this could happen if the vin plate and protecto plate was produced prior to changes made with options during the ordering timeline?
I appreciate any feedback, I want to fully understand this car.
Attachments - The Supercar Registry s-l225.jpg IMG_7127.jpeg IMG_7126.jpeg IMG_5278.jpg
Old 09-02-2025, 06:32 PM
markjohnson's Avatar
You have an original 6-cylinder car. The Cowl Tag will always state a V8.
The Following User Says Thank You to markjohnson For This Useful Post:
Arrowsmith (09-04-2025)
Old 09-04-2025, 03:46 AM
the original protecto plate that I have has the code F0329FA. In researching this that code on the plate represents
F- Flint Michigan
0329 - March 29 1966 - engine assembly date
FA - 427 CID / 425 HP - L72 engine with manual transmission (M21)
Old 09-04-2025, 03:53 AM
scuncio's Avatar
scuncio scuncio is offline
ID is the 427-425hp suffix code for a '66 full size Chevrolet.
Old 09-04-2025, 05:42 AM
Looks like you may need new research material, Ken. And unfortunately, reproduction ProtectoPlates are available from several sources....they can be made to say whatever the buyer wants.
Bill Pritchard
lowmile (09-04-2025)
Old 09-04-2025, 09:42 AM
Ralph Spears's Avatar
Ralph Spears Ralph Spears is offline
Default GM Dymotape
The Following User Says Thank You to Ralph Spears For This Useful Post:
Old 09-04-2025, 02:56 PM
TAR6569 TAR6569 is offline
If you can PM me the vin, I'll check my database and see if I have any info on the car
381 and counting in the 67-69 Impala SS427 registry
Old 09-04-2025, 03:50 PM
fsc66 fsc66 is offline
Default FA code engine
Not sure where you’re getting your information as to the “FA” code but see attached from the Lime Book
[email protected]
Old 09-04-2025, 05:12 PM
LT1vette LT1vette is offline
Is it a four speed car?
Old 09-04-2025, 09:00 PM
mssl72's Avatar
mssl72 mssl72 is offline
Yes, that. Not FA
Mark
1966 L72, 4spd Caprice
1974 Z28, M40 Camaro
