Old 08-23-2025, 11:28 PM
Default 2 barrel air cleaner assembly
NO LID INCLUDED. I needed the lid to use on a 327 four barrel AC I just put on the 57.
Study the pics. This will NOT fit a 307 or later 327 low performance two barrel. This fits the 350 two barrel. Those two carbs are different sizes. I am not 100% certain what this came on originally. I SUSPECT a 68 with 350 two barrel. I got it when I bough the El Camino which was originally a 307 PG car. The PO used a crappy adapter to make it "work" but it did not seal well. Charley sent me an old 327 air cleaner that I was able to use on that carb.
Look where the tab is on the mating surface and you will be able to tell orientation once installed. The thermac valve in the snorkel works. I have no way to test the actuating valve, but have no reason to believe it doesn't work.
Has the square hole for a breather filter (part of the PCV system) but I pirated the filter and retainer for my 57.
Gotta be someone out there preserving a 350 two barrel.
Just pay shipping.
Attachments - The Supercar Registry Super Chevy Indy 1.jpg IMG_3589.jpg IMG_3588.jpg IMG_3587.jpg
