Old 08-16-2025, 04:14 PM
bergy's Avatar
bergy bergy is offline
Default Re-pop versus OE sill plates
The re-pop sill plate have the rivets ( fake), but the Fisher tags are so incorrect.
Attachments - The Supercar Registry yenko 1967 sill plate.jpg IMG_6078.jpg IMG_0640.jpg Carpet Sill z.jpg
Old 08-17-2025, 05:06 AM
Kurt S Kurt S is offline
Just pull some original sill plates off of a car in a junkyard, preferably a 4-door, and salvage the Fisher plates/tags.
Then add them to some new sill plates with the original rivets and some glue.
Kurt S - CRG
The Following 4 Users Say Thank You to Kurt S For This Useful Post:
69Z11Pacer396 (08-18-2025), bergy (08-17-2025), enio45 (08-17-2025), mhm1966 (08-18-2025)
Old 08-17-2025, 05:10 AM
AnthonyS's Avatar
AnthonyS AnthonyS is offline
Yenko Advertising Member
^ I was typing something along the same lines!
Old 08-17-2025, 05:07 PM
Burd's Avatar
Burd Burd is offline
What year did the rivet go away, this is 90’s GM. For my 78,
It's only Orig once
waste all the rest.
1978 Y88
1995 Q45
Old 08-17-2025, 07:52 PM
bergy's Avatar
Anybody know if the rivet heads were painted on originals?
Old 08-17-2025, 10:50 PM
Burd,
At least for the Nova, the sill plate rivet when away in the early 70's. Sometime after 1971. I would have to go back and check my notes. The 1971 Chevelle also had the rivets.
Greg
The Following User Says Thank You to Nova Research Project For This Useful Post:
Burd (08-18-2025)
Old 08-17-2025, 11:03 PM
Hello bergy,
The rivets were painted on the originals. (Even though I left that out of my tutorial... http://chevynova.org/SillPlateRivetsInstall.html)
Greg
The Following 4 Users Say Thank You to Nova Research Project For This Useful Post:
169indy (08-18-2025), bergy (08-18-2025), ragtop (08-18-2025), RPO LS7 (08-17-2025)
Old 08-18-2025, 12:54 PM
bergy's Avatar
Thanks for the tutorial Greg - nice work! The OE sill plates for my car have contours that are quite a bit different than re-pops (not to mention that the re-pops are nearly as thin as tin foil). Also, all of the rivets that I removed are hollow in the center. So, I think I'll try polishing the originals & reattaching the rivets......... To be continued
see picture - re-pop is the sill plate that's installed.
The Following 2 Users Say Thank You to bergy For This Useful Post:
169indy (08-18-2025), olredalert (08-18-2025)
Old 08-18-2025, 03:56 PM
169indy's Avatar
169indy 169indy is offline
unpainted (Factory F body) -vs- painted (Trim Parts Repop)
I wonder if they came both ways.
& the Repops are narrow on the rear pinch weld cover interfacing
69 Los Z11
68 SS/RS 396/325
68 Los Z28
The Following User Says Thank You to 169indy For This Useful Post:
Old 08-18-2025, 08:22 PM
I agree, original sill plates had black rivets.
Greg, thanks for posting that link. Saved me from searching for it....
Kurt S - CRG
The Following 2 Users Say Thank You to Kurt S For This Useful Post:
169indy (08-18-2025), Nova Research Project (08-19-2025)
