Old 07-07-2025, 08:00 PM
Default 1968 Corvette L79 Engine 327ci / 350hp "HT" Code
I was trying unite this engine block with it's original 68 Corvette with negative results before listing for sale.
The engine (L79 Engine 327ci / 350hp Long Block) was removed in 1971, for it allegedly had a spun bearing I was told. It was replaced with a 307 engine.
The engine is not cracked, repaired or modified. The crank spins freely and the original pistons and rods were moved at some point, but are still with the engine. It will require to be rebuilt and the crank turned most likely. The block is standard bore and has no wear at the top lip of the bore, so I believe can remain standard bore.
The Double Hump Heads are also original to this engine and are factory with 202 Valves. I also have the original camshaft to this engine, along with the original Oil Pan.
I have nothing else for the engine.
Block Info:
- Front Pad: 18S420912 V0522HT (May 22, 1968)
- Block Casted Date: E 20 8 (May 20, 1968)
- Block Casting Number: 3914678
- Forged Steel Large Journal 327ci Crankshaft: 3914672
- Cylinder Head Number: 3917291
Cylinder Head Casted Dates: E 4 8 (May 4, 1968) & E 8 8 (May 8, 1968)
- VIN: 194378S420912
$2800.00 or Best Offer
No shipping pick-up only....I can delivery to Camaro Nationals in Morgantown, Pa July 18-19, 2025
67 Z/28 Butternut Yellow
69 Z/28 Rally Green
69 Z11 Pace Car
2010 2SS RS Aqua Blue
68 Z/28 Lemans Blue
2019 Corvette Grand Sport
68 SS Lemans Blue
69 RS/Z28 Maroon JL8
66 Corvette Ermine White L75
Tags
l79 327 350 ss
