Old 06-16-2025, 02:36 PM
67z28 67z28 is offline
Default 66 Chevelle steering column help
I need to reinstall a column shift steering column back in to a 66 Chevelle, and can't figure out the correct way to get the shift indicator arm back into the dash. The part I am struggling with is the spring steel piece that is in the bottom slot of the column and goes around the column and up into the gauge cluster. It is the arm that moves when you shift the car into reverse or drive that has the small orange tip. If anyone knows of any videos or can point me in the right directions it would be great.
