Old 04-25-2025, 01:40 AM
Default 1970 LT1 Camshaft
Is there a market for a used, original 1970 LT1 Camshaft 3972178, at what $$$$$$...No Lifters !!!!!!!!
How/Where/Who can verify that's its condition, if it "LOOKS" Good ????
Chuck Sharin
[email protected]
69 Camaro COPO "recreation"
Attachments - The Supercar Registry original cam brown paint.jpg original cam 2182 number.jpg
Old 04-25-2025, 01:52 AM
luzl78 luzl78 is offline
You should buy nos. There’s one on eBay now for $599. eBay #659178719
Old 04-25-2025, 03:13 AM
daverd daverd is offline
Get a new one by a good company made in USA !
2017 impala (wife’s car)
Old 04-25-2025, 03:15 AM
Old school nos means good metal, even though they can match the lt1 specs with new cams. Got to be wary of a new solid tappet without a roller option.
The Following 2 Users Say Thank You to luzl78 For This Useful Post:
cheveslakr (04-25-2025), L_e_e (04-26-2025)
Old 04-25-2025, 02:21 PM
If you are looking to sell it, I would be inclined to at least measure and state for buyers, using micrometers or similar, each lobe height as evidence of no wear. It can then be easily determined the amount of total lift against the spec of .459 intake and .485 exhaust. I did this on my original cam and found it to be within 0.002 of spec, but still went ahead and replaced it with a now discontinued Crane 119051 blueprint cam.
Owned since 1978 - First Car
Old 04-25-2025, 07:24 PM
Yes, I am wanting to sell it (NOT ON THIS SITE) but need to learn
1) If good machine shop can confirm the specs you gave
2) If it checks out what is the range of pricing/value
3) What are current LT1 builders buying if they are putting
together a OEM build 1970 LT1 engine
Chuck Sharin
[email protected]
Old 04-25-2025, 08:24 PM
Call Oregon cam grinding in Vancouver Wa......he'll be glad to help you identify the core as oem if you haven't already. I'd reuse an old cam that specs out far before I'd buy an off the shelf cam. OCG will also regrind your cam to factory specs or whatever you choose for $100. I wouldn't think it's worth more than $50 on the market, but if I was searching I'd probably pay a bit more than that.
Old 04-26-2025, 02:12 PM
Original cam has 2182 cast into it along with the brown paint mark. Has a date code also.
The Following User Says Thank You to BCreekDave For This Useful Post:
olredalert (04-26-2025)
Old 04-28-2025, 07:07 PM
Thanks Dave I'll look at mine............
Chuck Sharin
[email protected]
