Old 03-20-2025, 05:41 PM
ALLZS ALLZS is offline
Default Fan shroud
best way to remove spray paint from a plastic fan shroud
Old 03-20-2025, 06:16 PM
napa68's Avatar
napa68 napa68 is offline
I'm assuming you tried the variants of soap and water. Do you have some enamel reducer around? It may be worth a try
Old 03-20-2025, 07:35 PM
i will try that
Old 03-20-2025, 09:18 PM
67since67's Avatar
Maybe oven cleaner?? I've used that with success for cleaning plastic parts, don't leave it on too long.
The Following 2 Users Say Thank You to 67since67 For This Useful Post:
napa68 (03-20-2025), PeteLeathersac (03-21-2025)
Old 03-20-2025, 10:22 PM
Jonesy's Avatar
Jonesy Jonesy is offline
I have used a pressure washer to remove spray bomb paint with good success. The paint doesnt typically bond very well to plastic.
Old 03-21-2025, 01:29 PM
L78_Nova's Avatar
L78_Nova L78_Nova is offline
Plastic car modelers use brake fluid to remove paint from parts and bodies. I would test a piece of the plastic in it first. Must be soaked in it for day or two.
70 Chevelle SS-454 LS-5 M-22
The Following User Says Thank You to L78_Nova For This Useful Post:
169indy (03-22-2025)
Old 03-21-2025, 02:30 PM
Don't use brake fluid,use this,LA's totally Awesome Cleaner.I've been using it to strip paint and plastic chrome coatings off of plastic for years.It' will never hurt plastic and only dissolves paint or applied colors.https://www.dollargeneral.com/p/la-s...z/722429640222...You can get most anywhere,but cheapest at Dollar stores.
The Following 4 Users Say Thank You to Mr70 For This Useful Post:
juliosz (03-21-2025), olredalert (03-21-2025), PeteLeathersac (03-21-2025), ragtop (03-21-2025)
Old 03-21-2025, 05:36 PM
so do you have to soak it in this cleaner or just work it in
Old 03-21-2025, 06:55 PM
Soak it,not rub or spray on as it takes time to loosen the paint.I usually fill a tupperware container and put all my small pieces in it overnight un-covered & no gloves,(it's not caustic)...A good 12 or 24 hours should suffice at warm room temperature.Then rinse your item under running cold water and towel dry.
Being yours is a much larger item,I would buy a few gallons and soak half of it in a bucket or drum,then repeat on the other side a day later.
I re-use mine over & over & over again,after I filter out all the loose crap.
Once it turns dark & weakens,you can dispose down a sink/toilet.
Old 03-21-2025, 07:00 PM
great thanks
