Old 03-07-2025, 06:27 PM
dlv4540 dlv4540 is offline
Default 1963 327-300HP Engine #3782870 #3782461 X Heads
1963 327 standard bore block casting #3782870 dated L-13-2 cleaned and pressure tested with one sleeve installed. Block is stamped J179687 F1217RB out of a impala and was a 4 speed block.
#3782461 X heads dated K-23-2 & K-28-2 cleaned and magnafluxed.
Steel crankshaft with pulley and harmonic balancer
Water pump with pulley and fan spacer
Rods and pistons (7 pistons)
Air Cleaner
Timing Cover
Brackets and bolts
Clutch fork
Distributor (1960-62) #1110947
Can ship if you cannot pick up $2500.
Dennis Vugrinovich
Attachments - The Supercar Registry 20250306_130242.jpg 20250306_130240.jpg 20250306_130238.jpg 20250306_130228.jpg
Old 05-27-2025, 05:51 PM
sold
Dennis Vugrinovich
