Old 03-04-2025, 01:24 AM
hiperf69 hiperf69 is offline
Yenko Advertising Member
Default NOS! 12 bolt
Cleaning shelves, yes NOS 12 bolt parts
1965 “140” posi bare 3 series case
Box is dated 2-4-65
This is the early style Small Window square hole case.
They are a little harder to put together but a lot more beefy.
Plus, where will you find another one.
$450
1968 “174” std. 4 series posi.
This is what would have come in a “BV” style 12 bolt.
Someone wrote May 73 but box is dated 1968.
This is a Big window case.
$850
I know you can take an older posi and rebuild it or buy a New aftermarket
and in the Rearend nobody will know the difference, except you.
Gears
‘’Rare’’ 1970 “High Impact” 4:88’s.
These are stamped R50 which is 50 Rockwell .
All High Impact gear were drawn down to a lower Rc and that made them softer
for impact.
$450
4:88 std. gears. For production
These are dated 11-68 and 3-69
$350
1969/ 73 Dated 3:73 ring gear is dated ‘73 and pinion is dated ‘69.
When GM did this they didn’t throw anything away so if they were spread to far apart on dates they would ink stamp a number on both parts (045) in this case.
$450
3:31 dated 3-68 $400
3:08 dated 1967 $35- sorry should of been $350
Did I mention these are all GM and NOS!!
If you would like more picks, text and I will get that handled.
If you would like to bundle give me a call.
Thanks SYC!
Joe 608-751-0509
The Following User Says Thank You to hiperf69 For This Useful Post:
69 Post Sedan (05-02-2025)
Attachments - The Supercar Registry IMG_0641.jpg IMG_0635.jpg IMG_0634.jpg IMG_0632.jpg
Old 03-04-2025, 02:20 AM
RPOLS3's Avatar
RPOLS3 RPOLS3 is offline
Cool stuff Joe!
Jake Dykstra
Dykstra Motorsports
Old 03-04-2025, 01:01 PM
big gear head's Avatar
I'm sending you a text message. I tried a PM but got a message that you don't receive PMs.
Freddie
Old 03-04-2025, 02:05 PM
Thanks Fred for the heads up.
I will look into the PM Problem.
Shows I didn’t pre-read my ad,duh!
Sorry, 3:08 gear set should be $350 not $35-
Joe
Old 03-04-2025, 02:35 PM
Good morning SYC!!
I just sent Steve a message as I am having a Problem with receiving PM’S.
If you have had a problem getting through to me just give me a text at
608-751-0509
Thank You
Joe
Old 03-05-2025, 02:42 PM
Too Many Projects's Avatar
Originally Posted by hiperf69 View Post
Good morning SYC!!
608-751-0509
Thank You
Joe
You may have the option to receive messages turned off in your profile...which is the default setting, you need to turn this on.
In the blue bar near the top of the page look at the far left side and click "user CP"
From there Look at the left side of the page for Your Control Panel. It is a vertical menu of things you can do to customize your page(s).
Go to "Settings and Options and click on "Edit Options", scroll down to "Private Messaging" and click on the top option to ENABLE messaging.
You can do this !!
Mitch
1970 Chevelle SS
1966 Chevelle SS
1967 Camaro ss/rs
Old 05-03-2025, 11:27 PM
3:73,3:31 and 3:08 have been sold.
Thanks SYC!! and
Charlie for the referral !!
Hiperf69
Joe
