Old 01-18-2025, 11:47 PM
SuperNovaSS SuperNovaSS is online now
Default NOS GM Big Block Chevy 3959180 Camshaft L88 ZL1 LS7 BBC 396 427 454 In Tube
This is a New Old Stock GM camshaft for a Big Block Chevy Engine. The part number is 3959180. This cam is brand new in original GM tube. The part number on each box is 3916164. The 3959180 cam was used by GM in fthe second design 1969 L-88 and ZL-1 engines. This cam was also used in the infamous LS7 454 engines and was the choice of many racers and hot rodders with a high revving Big Block Chevy engine. This is a real deal NOS GM GM cam in the original tube. What a rare find!
This cam is in amazing unused condition as shown. It has never been used or installed and is in amazing condition. A few of the bearing journals have light surface corrosion that will clean off quickly. I wiped the cam down with WD-40 which will likely take the light surface corrosion off given a bit of time. They simply do not get nicer than this!
$949 plus the ride
Attachments - The Supercar Registry ZL1CamSpecs.jpg P1180610.jpg P1180609.jpg P1180605.jpg
