Old 11-28-2024, 03:21 PM
jl8z28 jl8z28 is offline
Default 67 rally sport headlights
Have a friend with a 67 rally sport replaced the parts headlights were working then one side stopped can't figure out what is wrong with it now anyone have any experience with them i did my 69 but they are vacuum advance
Old 11-28-2024, 05:14 PM
Rsconv68 Rsconv68 is offline
Check all the electrical (there’s more than 1) connections, especially ground wires, voltage at the limit switches, and voltage at the relays on the board.
Old 11-28-2024, 06:33 PM
1crossram 1crossram is offline
If they were working before correctly, it could be a poor ground as mentioned. Every limit switch has a ground wire, 4 switches. Check at the side not working. The headlight door should open by hand gently even if the motor stopped working. The motors can be checked by disconnecting the electrical connection and checking with a 12 volt power supply. Positive to one part of the connector, negative to the other. If you reverse the polarity motor should turn opposite direction. I have some spare parts and rebuild original motors.
1967 Camaro RS/SS convertible Butternut yellow with black power top, factory AC
Rebuilding 1967 RS headlight motors
Old 11-28-2024, 09:20 PM
Thanks for the response ill let him know
