Old 11-03-2024, 07:49 PM
toylman toylman is offline
Default 1969 Corvette 427 survivor Smog system
Survivor Smog or Air Injection Reactor system from a 1969 427 corvette engine. All parts are original used parts; No reproduction parts. Pump is dated June 30th, 1969 stamped 18191S, diverter valve is stamped 29298, check valve both stamped 5361992, hoses are stamped 3946007 GM RF KV, 3951353 GM RP, Wittek clamps are 1 1/16" dated 1/69 (1st quarter of 1969) one is not legible, pulley is stamped 3925522AQ. Brackets, pump back, diverter muffler, tubes, pulley all appear to have original finishes. Original hardware; pulley bolts, pump adjuster bolt, pump bracket bolt with original self locking nut, diverter bolts, pump case bolts. Original white pump fan with No damage. Threads and nuts on tube ends are excellent. Pump spins and puffs as it should; Not frozen. Outer side of pulley has the same black paint as the back with the stamp, the camera flash make it look gray. These original hoses, according to the NCRS Judging Guide are specific for a 390HP or a L88; see last picture. In addition, the missing valve diverter adjuster plate is available in reproduction from Zip and Chaicago Corvette at 125.
Overall very clean and retains most of the original factory finishes. The bracket which mounts between the diverter valve and the pump is missing/not included. Pick up at my house in Bethlehem, PA or can ship. Call me with questions. 908-418-2684 before 9pm EST. 1600. plus actual shipping cost if needed. I do not visit here that often so email [email protected] or call/text my number. Thanks, Lenny
The Following User Says Thank You to toylman For This Useful Post:
olredalert (11-16-2024)
Attachments - The Supercar Registry DSCN0612.jpg DSCN0611.jpg DSCN0610.jpg DSCN0608.jpg
Old 11-07-2024, 12:33 PM
TTT + additional information
Old 11-07-2024, 12:36 PM
ttt
Old 11-22-2024, 12:17 PM
Sold
