Old 09-04-2024, 06:25 PM
169indy's Avatar
169indy 169indy is offline
Default 1100843 0J17 Alternator
I have a nice 1100843 0J17 for 1971 Chevrolet<?>. Unit spins Rebuilt, & Tested w/ proof. freely and works. I rebuilt using new parts from a Kit (Bearings, Diodes, Brush Holder, New Brushed and Springs Capacitor & Hardware and cleaned and reinsulated (John C Dolph Air Cured (AC41) insulating varnished the Rotor and stator windings & steel core-laminations. Groomed the Case (Walnut blasting) to give a nice fresh appearance. 37amp version. I had the fan and pulley zinc plated. I took the ALT to local Autozone and tested SAT, do not be concerned about the 1.7 field amps tagged as unsat, we pulled two NEW alts from Autozone shelf and they tested same results. One Case bolt missing- tapped hole problem; this will Not affect function. (*Discounted price). Keep in Mind just the Rebuild Kit is 50 bucks. Not to mention the extent I worked this unit (Labor) and provided Objective PROOF of operation.
$125 plus the ride, double boxed.USPS Ground Advantage (Paypal F&F)
Please
Thanks
Jim
69 Los Z11
68 SS/RS 396/325
68 Los Z28
Attachments - The Supercar Registry DSC06673.jpg DSC06670.jpg DSC06669.jpg DSC06666.jpg
