Old 08-20-2024, 08:55 PM
Andy Andy is offline
Default 1967 Camaro Upper Door Hinge Rebuild
Well, after 26 years of ownership my upper door hinge has begun to sag on the drivers side. I'd prefer to rebuild the original hinge if possible rather than replacing it with an aftermarket part. Those of you that have done this, have you been able to find GM pins or are there aftermarket ones that actually fit? I ran across this GM part number (20046147) in my search last night and per what I've read, it should work, but I may have to cut some length off of the pins to make them the correct length, which is no big deal. I haven't dug up a part number yet for the bushings, so if any of you have one, it would be much appreciated. Thanks.
Andy
1967 Camaro 406 4 speed
1969 C/10 383 5 speed
1969 D300 318 4 speed
1969 Super Bee 383 4 speed
1972 K/5 350 Turbo 350
1972 Duster 340 727
1974 'Cuda 340 4 speed
Attachments - The Supercar Registry A5B533B0-1414-4C16-B888-57DA29E80B33.jpg 9203AB4E-1AAD-4BC2-AB3A-B9543D049E8B.jpg 5C341900-B473-42B6-8C1A-A0BE28B6B901.jpg 5C01F555-3FDD-4134-8317-865AF34ADE8E.jpg
