Old 08-15-2024, 07:30 PM
169indy's Avatar
169indy 169indy is offline
Default GM Temperature Sender Testing Device
GM Temp Sender Testing Device, for Gauge Sender & wiring, 1 each
Here is a Handy test and troubleshooting electrical device I have designed and built to enable GM Car owners to accurately test and trouble shoot your Engine sender chassis wiring for Vehicles with Gages. This can be used in seat, the wires are long enough to reach to Front of the car while you operate the knob controlled potentiometer test box thru the ranges (75-575 ohms). The Black lead to ground and the Red lead to your engine wire harness (GREEN) Eng Compt in line connector (GM-Packard Series 56 female). Alligator clips for convenient connections. The Potentiometer rage is to "Drive" the gage needle only for testing troubleshooting only Not a Calibrated driver due to variable temp to resistance curves for the various manufactured senders (i.e. Wells, Standard, AC Delco Vintage, Latest Delco, Etc) Sender resistance to Ohms ranges.
USD: $50.00 + 12.00 USPS priority Small box Shipping.
Paypal or M.O.
69 Los Z11
68 SS/RS 396/325
68 Los Z28
Attachments - The Supercar Registry DSC06590.jpg DSC06589.jpg DSC06588.jpg DSC06587.jpg
