Old 08-12-2024, 09:21 PM
rm70z rm70z is offline
Default Eaton cv clutch fan assembly
Original GM CV Eaton Clutch fan assembly. Used on 1969-70Z28 Camaro L78 LS6 Chevelle
Was removed from a 1970 Z 28 back in the 80s , It was sprayed with penetrating oil has surface rust but clutch fan is super tight no bends cracks. I would try Evaporust first to clean but the clutch is tight does not need to be restored .Comes with hardware bolts /washer. If you want to see the clutch fan blade 772 that was taking off of it is listed separate .
$295 plus ship
Thanks
Attachments - The Supercar Registry IMG_1568.jpg IMG_1567.jpg IMG_1566.jpg IMG_1565.jpg
Old 08-13-2024, 03:24 AM
combinefixer combinefixer is offline
I’ll buy this unit. PM sent.
134379 L78 M22 in 61 61
