Old 08-05-2024, 01:16 PM
bills69 bills69 is offline
Default Connecticut steel wheel repair
anyone know of a Connecticut steel wheel repair
need Z28 wheels checked out
Old 08-05-2024, 02:19 PM
MosportGreen66's Avatar
Depending on where in CT you are, Westchester Wheel Repair in Verplank (near Indian Point) does a really nice job on straightening wheels. State of the art equipment too.
The Following User Says Thank You to MosportGreen66 For This Useful Post:
RPOLS3 (08-05-2024)
Old 08-06-2024, 01:54 PM
trying to determine bad new tires or wheel
Old 08-06-2024, 05:26 PM
useless tony useless tony is offline
Good luck. Bump.
Old 08-06-2024, 09:34 PM
Too Many Projects's Avatar
I agree with Tony but leave the tires on and spin them assembled first. If there is an out of round, or bulged sidewall on a tire, it will be the first place to start. It's possible one of the wheels wasn't balanced properly and be corrected at that time too.
Bent wheels will be evident with tires on too, but a bit less obvious. If a wheel is suspected of being bent, the spin balancer operator can use the depth gauge against the wheel and rotate by hand to watch how much the gauge moves side to side.
Mitch
1970 Chevelle SS
1966 Chevelle SS
1967 Camaro ss/rs
Old 08-07-2024, 01:40 PM
Been balanced 3 times . All looked good on the balance machine
Borrowed friends tires/wheels vibration gone ,
Now have to find bad wheel or bad new tires
Old 08-07-2024, 01:49 PM
OK, getting somewhere now...did you drive this vehicle with the same wheels but different tires before getting new ones ? If so, was the vibration present then ?
Mitch
1970 Chevelle SS
1966 Chevelle SS
1967 Camaro ss/rs
Old 08-07-2024, 05:07 PM
Good luck. Bump.
Old 08-08-2024, 01:28 PM
next step is swap a wheel at a time and then determine wheels or tire
The Following User Says Thank You to bills69 For This Useful Post:
Too Many Projects (08-08-2024)
Old 08-08-2024, 09:54 PM
Good luck. Bump.
