Old 07-03-2024, 08:28 PM
XXXGoldL34M20's Avatar
Arrow 1970 Chevelle ZK9 CD2 Windshield Washer Fluid Level Indicator System Tested and Works
Part of the ZK9 Auxilary Lighting Group option or some models offered this as a CD2 option code on it's own called Windshield Washer Fluid Level Indicator. Assembly line system with a perfect original wiring harness that pig tails to the washer motor assembly, inside float is excellent with NO cracks and red/green lens is still fuctional on its float. BP 3961557 original square bottom washer bottle is very good with some yellowing and one mounting area has a tiny split but hard to see (Photo shown). Comes with original "D" stamped mounting hardware. Cap with rubber hose and bottom screen pick up comes from GM NOS over the counter stock. Unit was tested and works like it should (See photos). Fiber optic line is original GM with no issues and Washer Fluid Eye unit is excellent while the tiny guide tab has snapped off but once screwed on it will work just fine.
$575 plus $22 Tracked shipping from Canada Paypal FF
