Stupid question, as no one in the Opel world seems to car about originality, but...
My original radiator cap tests at a whopping 3 psi... max. Should be 13 psi. Who is restoring radiator caps. M22Mike on this site, used to do them, but he is MIA (has not posted since 2021). As you can see, it has German script on the cap. Would like to have this one restored if that is possible. Guess, I could just take the rubber seal off a newer cap and try that. After all, this isn't a "recovery" type cap. Can't imagine that the spring is the culprit. Suggestions?
| The Following User Says Thank You to Lynn For This Useful Post: | ||
Washburn-Z28 (05-14-2024) | ||
Try Jeff Ashen - Pacecar Jeff. I just bought 2 restored ones from him - assuming he will restore others is not in his stock?
| The Following 3 Users Say Thank You to RPOLS3 For This Useful Post: | ||
1968 Z/28 Corvette Bronze. Black Hounds Tooth. 02E Los Angeles born 3/13/1968 pnt OO 1969 SS396 Yellow/Yellow 08E Norwood born 8/28/1969 pnt 76E 1970 'cuda Moulin Rouge, 440-6, 4 speed |
| The Following User Says Thank You to X66 714 For This Useful Post: | ||
Tim does excellent work.
Richard 1967 Camaro SS 396/375 4K 2002 Camaro 35 Anniversay Z4C-WU8 |
| The Following 3 Users Say Thank You to 1967 4K For This Useful Post: | ||
Thanks.
On a side note, anyone know what happened to Mike?
