Old 01-09-2024, 01:11 PM
67SS4spd's Avatar
67SS4spd 67SS4spd is offline
Yenko Premier Member
Default Misc Chevelle, Big Block Chevy, GM and aftermarket parts for sale
GM Parts - Chevelle
• 67 GM - 4 headlight buckets and trim rings - $60.00
• 66-72 GM bucket seat tracks - glass beaded $120.00 sold as a set of 2 pairs
• 67 GM 5000 redline tach - $40.00
• 67 GM Steering column clamp @ firewall - auto - glass beaded - $20.00
• 67 GM - Postive battery cable frame clip (@frame horn) $35.00
• 66-67 GM NOS door edge guards - $50.00
• 67 GM Non-AC kick panels molded in Black - $150.00
• 67 GM wiper motors, 1 works / 1 good for parts? - $20.00 / $10.00
• 66-67 GM assorted cluster gauges - $5.00 ea
• 67 GM gauge cluster w/clock - column shift no harness - $85.00
• 67 GM gauge cluster w/clock - Floor shift w/harness - $250.00
• 67 GM gauge cluster w/clock - Floor shift no harness - $175.00
• 67 GM taillight extensions L and R w/ bezels - all studs there - $100.00
• 67 GM tail lamp lenses L and R - $75.00
• 67 reverse lenses - new in bag - $10.00
• 67 GM defroster duct - $75.00
• 67 GM wiper linkage - $75.00
• 67 GM bucket seat metal back driver’s side - $50.00
• 67 GM front bumper - straight core - $50.00
• 67 GM front bumper brackets - $40.00
• 67 GM wood grained dash strip - $75.00
• 66-67 GM quarter window bottom guide glass attachment plates - $25.00
• 66-67 upper alternator bracket - $25.00
• 66-67 GM door hinges, NOT rebuilt - $40.00 ea - sold as a set (2 doors)
• 67 GM Parking brake switch - $50.00
• 67 GM Power drum brake master cylinder
# 5460465 / D3-149 and booster, not rebuilt - $75.00
• 66 GM AC control unit - 1 broken #4 bottom arm - $100.00
• 67 GM Non-AC control unit 1 broken arm - $65.00
• 67 GM Non-AC control unit complete - $120.00
• 67 GM accelerator bracket assembly - $80.00
• 66-67 GM driver and passenger door window gear actions - $60.00 both doors
• 66-67 GM driver and passenger door glass guides - $60.00 both doors
• 66-67 GM driver and passenger door lock latches with rods - $140.00 pair
• 66-67 GM ash tray and slide - $100.00
• 66-67 GM glove box door with striker - $100.00
• 67 GM steering column collapsible Mast - $75.00
• 67 GM steering column shift bowl - $10.00
• 67 GM steering column upper bowl - $15.00
• 67 GM steering column upper bowl - $10.00
• 67 GM steering column lower sleeve at dash - $35.00
• Qty (1) GM Rally XG code 14x6 - $75.00
• 66-67 GM windshield trim, sides and tops - $20.00
Chevelle and Other
• GM TRW 3881456, L-78 - 11:1 pistons, like new. - $350.00
• 67 Camaro block 3902406, 2 bolt, Std bore with VIN - $1400.00
• 6223 forged crank 10/20 - $200.00
• 67 for 68 3917215 closed chamber heads - $400.00
• 67 3909802 heads $700.00
• 71 GM upper fender tie bar, nice piece - $35.00
• 69 GM (pair) shoulder seat belts ( shoulder only-male ) - Black - $40.00
• GM Seat belt headliner clips - ( set of two pair ) - $15.00
• 69 GM Chevelle big block oil pan - clean - $100.00
• 69-72 GM trunk lock and 2 GM keys - $10.00
• 71 GM Quadrajet throttle cable and trans kickdown bracket, starter wire tube, valve cover to air cleaner tube - sold as a set $50.00
• 67 GM BOP bucket seat metal back passenger side with chrome trim inlay - $50.00
• 72 GM rear defroster Dated 2/72. Nice shape, works great - $100.00
• 68-72 GM rear upper Control arms - no pit, nice shape - $25.00
• GM 3858403 - 153 tooth bell housing - glass beaded - clean - $100.00
• 67 GM Impala / Caprice AM radio - $20.00
• 64-72 GM 3/4” front sway bar - $50.00
• 64-67 GM upper A-arm cross shafts larger square style- glass beaded - $25.00
• Quadrajet 7042220 L1 EM (72’ ?) - $75.00
• Quadrajet T029244KA 125/9 week 19? - $75.00
• GM Re-chromed column shift lever - $20.00
Repop or other Mfg’r parts -
• Cal-Custom 10 fin polished aluminum bbc valve covers with drippers - $300.00
• 67-67 headlamp trim rings - new - $25.00
• 66-67 Front arm rest bases, new - $30.00
• 66-67 Front arm rest black pads like new - $20.00
• 66-67 set of quarter window vertical chrome - $25.00
• 64-72 lower rear boxed control arms - new - $50.00
• 64-67 upper rear 12 bolt control arms - new - $50.00
• 64-67 rear upper heavy duty control arms for conical bolt adjustable pinion angle - very Clean - BOP I believe, GM pieces - $125.00
• Bosch water temp, oil press, Alternator gauges, never used - $15.00
• Qty 4 - door panel springs @ window cranks $5.00
• Box of seat spring wire staples - $10.00
• Upper and lower front China-PP A-arms, upper ball joints removed - $75.00
All prices do not include shipping.
Make offer or possible trades -
Looking for a 2406 Chevelle 396 block.
Looking for an a, b or c dated 67 / 61 amp alternator
Looking for a 67 stock distributor
Looking for a Fly Eye air cleaner
Looking for a Cal Custom GM 12 bolt differential cover
Looking for 1 DG 14" Rally Rim
Thanks for looking...
Please email for inquiries or photos
[email protected]
1967 Chevelle big block Chevy GM 396
Old 01-09-2024, 03:41 PM
69L78's Avatar
69L78 69L78 is offline
email sent on the 69 BB Oil Pan
Old 01-09-2024, 04:30 PM
67since67's Avatar
This list could have came from my attic......
Some good pieces there, GLWS! - Bill W
