Old 01-03-2024, 04:19 PM
dlv4540 dlv4540 is offline
Default 1960-69 283 302 327 350 396 427 SBC & BBC Parts & Engines
1960-62 #1110947 distributor $35
1962 #3782461 X heads both dated A-5-2 $1250
1963 327-300HP turbo fire engine complete from the air cleaner to the steel crank.
#3782870 standard bore block dated L-13-2 stamped J179687 F1217RB for a 327-300HP 4 speed block. Block has one quarter size hole in the middle of one cylinder requiring a sleeve. Can have fixed or you can have your machine shop repair it. I wanted the damage to be seen.
#3782461 X heads both dated L-15-2
#3797942 & 3797901 factory exhaust manifolds
#3844459 intake dated B-6-5 with factory AFB Carter carb shown as a factory service replacment intake from 1963-65
Steel Crankshaft uncut
Factory turbo fire valve covers
Factory air cleaner base and lid
Factory water pump with original pulley and has a aftermarket fan blade
Factory crank pulley
Factory timing cover
Factory original rods with seven pistons
Sell the whole engine for $3,000 or seperate out.
1967 factory 11 inch 168 tooth flywheel #3729004 dated E-14-7 $200
1968 327 long block
#3914678 standard bore block dated K-6-7 stamped T1109YC
#3917291 heads dated J-11-7 & J-12-7
#39411740 cast uncut crankshaft
Factory pistons and rods
$1,000 for the whole set up or will seperate out.
1969 #3927186 heads 2.02 valves dated I-18-8 & K-5-8 $900
1969 #3927186 heads 1.94 valves both dated D-29-9 $750
1969 #3927186 single head dated G-25-9 $350
1969 #3927186 heads both dated K-30-8 complete 2.02 heads $900
1969 #L-13-8 & L-18-8 1.94 valves complete $800
Can ship and can provide pictures as well. A lot of the parts have been cleaned and magnufluxed or if needed can have done as well. Any questions 330-770-2517
Dennis Vugrinovich
Old 01-05-2024, 06:40 PM
Gave a buddy your contact info that isn't on this site for the April 186 heads. His name is Fred and he's a good guy. Thanxs Dave
67 Z/28 Butternut Yellow
69 Z/28 Rally Green
69 Z11 Pace Car
2010 2SS RS Aqua Blue
68 Z/28 Lemans Blue
C7 Corvette
68 SS Lemans Blue
69 RS/Z28 Maroon JL8
66 Corvette Ermine White L75
Old 01-29-2024, 02:47 PM
Yes I talked with him he had a car first week of may and decided that my set of April 2 1969 heads were to early for his build. I told him he should look into that because I disagree but he wants them rite on top of the build for some reason. Thank you for the opportunity.
Dennis Vugrinovich
