Old 12-07-2023, 02:38 AM
Default 2003 Chevy 3500 Dually 6.6L Duramax 72,000 miles
Original Owner 2003 Chevrolet Silverado 3500 LT Duramax
Description-
I’m the original owner of this truck, having purchased it in 2003 with 299 miles. The truck is in excellent condition, and everything works like new. DEF is not required. This vehicle has not been modified other than a fuel lift pump was added when all 8 injectors were replaced in 2015. At that time a 350 hp tune was flashed to the ECM. When this truck was manufactured the LT trim level was the top.
Carfax shows an odometer discrepancy due to shop that performed an oil change on 7/16/2020 entering the wrong odometer reading. A photo of the current odometer reading is included in the ad.
Equipment-
Duramax Diesel 6.6 liter V8 engine
Allison 5 speed automatic transmission
Dual zone automatic air conditioning
Inside rearview mirror with compass and tint
Dual power outside rearview mirror
Rear window defogger
Deep tint glass
Front fog lamps
Pioneer double din radio with cd, Android Auto/Apple Car Play, and backup camera
Steering wheel controls for radio and cruise control
Bose speaker system
Leather wrapped steering wheel
Cruise control
Intermittent wipers
Power door locks and windows
Dual power driver and passenger front seats with heat
Locking differential rear axle with 3.73 ratio
Camper/5th wheel trailer wiring
Frame mounted gooseneck hitch
Retracting outside rearview mirrors with turn signal and heat
Heavy duty trailering equipment
Service History
August 2003 – Took delivery of the truck, 299 miles
June 2005 – Replace passenger side rear view mirror, 7676 miles
2005 to 2008 – I’m unsure of the date or mileage as I have lost the service invoice from the dealer who did the repairs, and they are no longer under the same ownership. Somewhere in this time frame the truck developed heavy black exhaust and was taken to a Chevy dealer. Problem was diagnosed as bad injectors and 3 or 4 were replaced. Only the faulty injectors were replaced at this time. This is a well-documented problem with the Duramax LB7 engine and GM extended the engine warranty to 10 year or 100,000 miles. Whichever occurred first.
April 2008 – Replaced serpentine belt and tensioner, 48000 miles approx.
June 2011 – Replaced volume control switch in steering wheel, 50039 miles
August 2014 – Replace fuel filter housing and both fuel lines, 52572 miles
September 2015 – Replaced all 8 injectors and added Raptor fuel lift pump, EFI Live Single 350hp Tune, 55700 miles approx.
October 2015 – replaced left and right-side headlight assemblies, replaced left and right-side parking/turn signal assemblies, replaced upper and lower radiator hoses
September 2016 – Replaced lower A-arm bumpers, changed transmission filters, replaced a/c actuator, replaced all 4 shocks with Bilstein shocks
September 2016 – Installed new double din Pioneer radio with Android Auto/Apple Car Play and backup camera
June 2019 – Front end alignment, rotate and balance tires, 63321 miles
March 2021 – Replaced a/c compressor clutch
April 2021 – Replaced both 78 Series Batteries, 69055 miles
February 2023 – Changed fuel filter and engine oil and filter, 71,895 miles
Price - $35,000 obo
It's better to PM me as I don't check back but every couple of days.
Howard
Attachments - The Supercar Registry IMG_4344.jpg IMG_4343.jpg IMG_4342.jpg IMG_4341.jpg
