Old 11-23-2023, 09:15 PM
dannystarr dannystarr is offline
Default 3:73 Ring & Pinion 12 Bolt
This is a set of used GM 12 bolt 3:73 gears I purchased off this site. I have since found a set that matches the car better. I had these inspected by a friend with knowledge in setting up rears. I mentioned the little rust spots and asked if that was an issue. He said they are minor, and the oil will take up the slack and there should be no noise. They are dated Ring Gear 11/67 Pinion Gear 8/67
$200 plus S/I. Danny
Attachments - The Supercar Registry 20221031_190201.jpg 20221031_190154.jpg 20221031_190146.jpg
