Old 11-19-2023, 12:53 AM
wvhylander wvhylander is offline
Default BBC Air cleaner base
I changed from vacuum secondary Holley to a DP carb. The pvc tube on my factory base hits the secondaries. The factory L88 is the only BB that I'm aware of that had a DP holley. All the repo drop bases look the same and list as fitting all Chevy BBC with a Holley including the L88. What's different about the factory L88 breather that clears the secondary accelerator pump?
Old 11-19-2023, 06:53 AM
John Brown's Avatar
Not sure about factory L88 bases, but some of the reproduction bases have a down tube with two 45 degree bends instead of a 90 degree bend, will and work with a double pumper.
John Brown
Old 11-19-2023, 11:02 PM
I knew I'd find the answer here! Thank you
Old 11-20-2023, 05:52 AM
big gear head's Avatar
I didn't know that the L88 had a DP. I thought it was vacuum.
Freddie
Old 11-20-2023, 06:47 AM
The second design l88 in 1969 went to a 850 double pumper. The list number was 4296. It and the list 4295 carb used on the 1969 z28 crossram were the first double pumpers made by Holley. It was a turning point in Holley performance.
The Following 4 Users Say Thank You to SuperNovaSS For This Useful Post:
69M22Z (11-20-2023), big gear head (11-20-2023), dykstra (11-20-2023), olredalert (11-21-2023)
Old 11-20-2023, 02:19 PM
John Brown's Avatar
The 3418 was a vacuum secondary carb, then in 69 they changed to a 4296, which was a double pumper. Just for the record, I have never run across a plain 3418, only 3418-1's. Strange.
John Brown
The Following User Says Thank You to John Brown For This Useful Post:
Old 11-20-2023, 03:11 PM
Thanks for clearing that up for me guys. Did the ZL1 also get a DP?
Freddie
Old 11-20-2023, 03:32 PM
John Brown's Avatar
Yes, the 69 Camaro aluminum engined ZL1 used the same 4296 carburetor as the 69 L88 iron block Corvette engine.
John Brown
Old 11-20-2023, 03:41 PM
William William is offline
The AMA specs for the ZL-1 Camaro list the #4296 but none of them were built with it due to the same fitment issue. Vintage photos show the production GE code #4346.
The Following User Says Thank You to William For This Useful Post:
