Old 10-25-2023, 07:02 PM
brent396's Avatar
brent396 brent396 is offline
Default 1969 Camaro dash pad
Looking for a survivor black pad or who makes the best repro pad
1968 ChevyII 396 375,1969 Camaro 396 375 survivor , 1969 Dynamotion Copo Camaro,1968 L 79 ChevyII ,1969 Camaro 427 ratsness ,1967 Chevelle L79
Old 10-26-2023, 01:01 PM
Copo_Cartel's Avatar
Copo_Cartel Copo_Cartel is offline
Yenko Premier Member
Brent I have an assembly line GM dash pad without the bald spot . Those are over the counter pads.
Old 10-29-2023, 11:19 AM
brent396's Avatar
Found one thanks syc for all the help
Old 10-29-2023, 04:01 PM
As long as there is a thread going on this subject, I have a question about the repops.
When I was putting my car together 10 plus years ago, I had an OER repop that absolutely would not fit. I sold it for $100 and found a used GM over the counter pad (with the infamous bald spot). Like everything else I buy, I over paid because it was genuine GM. The underlying fiberglass structure was very brittle. I had to reinforce several places using aluminum, epoxy and pieces of the substructure from an original beat to death dash pad; but it fit reasonably well.
Fit is still reasonable, but it has two issues:
1. It still outgasses, making the surface a bit sticky. It is easy enough, albeit a bit time consuming, to fix each year using car wax judiciously and wiping it clean with terry cloth. Kind of a pain.
2. There are a couple of places on it that I describe as "roached out" where the surface is very rough, like maybe it got a bit hot. I see no way to fix that, so have just lived with it.
Because of the above, I was watching this thread. I remember, right after I put my car together, CHQ (or someone) supposedly came up with a retooled repop that looks great and fits perfectly. As with all things repop, I am a bit skeptical.
Summit has two dash OER brand dash pads, both without A/C, with two different part numbers and two different prices. Is one a leftover of the crappy fit series?
3995785 for $369.99
https://www.summitracing.com/parts/o...SABEgLqYPD_BwE
3935941 for $314.99
https://www.summitracing.com/parts/o...D_BwE#overview
I have zero confidence that calling Summit result in a sales rep that can tell me the difference.
Old 10-29-2023, 09:59 PM
Danzo Danzo is offline
Lynn, discussed here.
Doc.
http://www.camaros.org/forum/index.p...7482#msg187482
Old 10-30-2023, 03:28 PM
Steve Shauger's Avatar
Administrator
Default Dash Pads
Lynn we have a new sponsor Camaro Central. They are incredibly knowledgeable on all Camaro related products. They do stock CHQ dash pads.
They do have a special Halloween special $30 off purchases over $300. Check with them you might be able to save some money.
Link:
https://www.camarocentral.com/
www.vintagecertification.com
Old 10-30-2023, 04:25 PM
Thanks Steve.
Old 11-09-2023, 01:55 AM
Got the new pad installed this evening. Only two fitment issues. 1. I had to use an exacto knife to trim off some flashing where the spring clips mount to the pad. Not a big deal. 2. The little ear on the driver's side is a bit thicker than the GM pad. I cannot get it to fit between the dash and the kick panel trim. All other fasteners lined up very well with minimal pulling/pushing.
Guys "in the know" will be able to tell it isn't original GM, but overall, way better than most aftermarket POS stuff.
The Following 2 Users Say Thank You to Lynn For This Useful Post:
Steve Shauger (11-09-2023), Woj (11-09-2023)
