Old 10-09-2023, 05:59 PM
Default Factory & Day 2 High Performance Parts 60's-70's True Vintage NO RESERVE AUCTIONS
I have a number of factory and period correct high performance parts up for auction on Ebay. Each auction started at $9.99 and has NO RESERVE. These auctions all end this Sunday at 7 PM Pacific Time with the exception of 2 valve cover auctions that end on Saturday night. These are great parts and there are bound to be some great deals.
Below are links to the auctions and there are some pictures below the links.
OEM GM Open Element Air Cleaner Factory High Performance 4 Barrel Carb 60s Chevy
https://www.ebay.com/itm/374970864529
GM 3 Spoke Wood Steering Wheel 67 68 Camaro Chevelle Impala Nova 64-66 Corvette
https://www.ebay.com/itm/374970857556
Sun Chrome Gauge Cup Model GC 2 5/8 Gauges Blueline Greenline 60's Hotrod Day 2
https://www.ebay.com/itm/374970843662
1960's Shelby Cobra 9,000 RPM Tachometer Very Clean Original
https://www.ebay.com/itm/374970828210
60s-70s Sun Super Tachometer 8,000 RPM SST-802 Muscle Car Tach Hot Rat Rod Day 2
https://www.ebay.com/itm/374970820411
Vintage Cal Custom Big Block Chevy Valve Covers Hot Rod Muscle Car 396 427 454
https://www.ebay.com/itm/374969095979
NOS Bill Thomas Performance Handbook Big Block Chevy 396 Nickey Real Deal 1965
https://www.ebay.com/itm/374969095975
OEM GM Corvette Finned Aluminum Valve Covers 3726086 SBC Staggered Pattern
https://www.ebay.com/itm/374969095973
OEM GM Small Block Chevy Timing Cover 8 Inch Balancer AO Pointer Early 60's
https://www.ebay.com/itm/374969054290
NOS GM Big Block Chevy 3916164 Valve Springs Purple Stripe Heavy Duty Set of 16!
https://www.ebay.com/itm/374968926427
OEM 1970-1972 Camaro Z/28 Dual Snorkel Air Cleaner Assembly Original Paint
https://www.ebay.com/itm/374968523218
OEM GM SBC High Lift Rocker Arms "O" Markings Small Block Chevy 302 327 350 LT-1
https://www.ebay.com/itm/374968476359
NOS Sun Bat O Meter Voltage Gauge 12 Volts Hot Rod Factory GMC Truck Option 12V
https://www.ebay.com/itm/374968409333
Holley List 4777-2 650 CFM 4 Barrel Double Pumper Carb Hot Rat Rod Muscle Car
https://www.ebay.com/itm/374968289088
Original 60's-70's Shelby Accessory Real Wood Steering Wheel Real Deal
https://www.ebay.com/itm/355084622486
Sun Blueline Oil Pressure Gauge 60's-70's Hot Rod Muscle Car Day 2 OIL-80B
https://www.ebay.com/itm/355084607069
Sun Blueline Water Temperature Gauge 60's-70's Hot Rod Muscle Car Day 2 WT-260-B
https://www.ebay.com/itm/355084601753
1960's Buick Factory 7,000 RPM Tachometer REAL DEAL OEM Tach 6411300
https://www.ebay.com/itm/355084587060
Original GM Big Block Chevy Aluminum Intake 3885069 396 427 1/31/66
https://www.ebay.com/itm/355082345431
OEM GM Small Block Chevy 8" Harmonic Balancer 3817173 Finned Early 60's C65 Date
https://www.ebay.com/itm/355082323261
Vintage OEM GM 3906656 Water Pump Pulley Big Block Chevy 396 427 454 BBC
https://www.ebay.com/itm/355082144010
NOS GM 3863143 Camshaft Big Block Chevy Solid Lifter 396 427 454 Yenko COPO LS6
https://www.ebay.com/itm/355082078500
NOS GM Truck Front Mount Spare Tire Carrier 994333 Pickup Blazer Suburban IN BOX
https://www.ebay.com/itm/355082053646
1968-1970 AMC Javelin Factory Hurst 4 Speed Shifter & Rods 6781 Handle 3138 Body
https://www.ebay.com/itm/355081659545
Vintage Stewart Warner 8,000 RPM Tachometer 5 Inch Diameter Traditional Hot Rod
https://www.ebay.com/itm/355081488038
1968 1969 AMC Javelin Factory In Dash Tachometer American Motors Tach WORKS
https://www.ebay.com/itm/355081466816
OEM GM 348 409 Chevy Chrome Valve Covers Bowtie W Motor Engine Factory Chevrolet END SATURDAY!
https://www.ebay.com/itm/374968345093
OEM GM Big Block Chevy Chrome Valve Covers w/ Oil Drippers 1960's-70's END SATURDAY!
https://www.ebay.com/itm/355081423686
OEM Ford GM Hurst 4 Speed Shift Knob T Handle 1970 1971 Mustang Cougar GTO
https://www.ebay.com/itm/374971122529
Factory Mopar 6,000 RPM Console Mounted Tachometer Dodge Chrysler Plymouth
https://www.ebay.com/itm/374971131427
OEM GM Accessory Front Seatbelts Fisher Carriage Chevy Buick Olds Pontiac
https://www.ebay.com/itm/374971145247
Thanks for the ad and good luck bidding,
Attachments - The Supercar Registry Yenko5.jpg Yenko4.jpg Yenko3.jpg Yenko2.jpg
