Old 10-01-2023, 01:06 AM
RALLY RALLY is offline
Default Brake Master Cylinder rebuilder?
Looking for a good brake master cylinder rebuilder for a 72 Nova? Any good businesses that do this you would recommend. Thanks you.
Old 10-01-2023, 04:30 AM
If the bore has zero pits, then just about anyone can rebuild it.
If the bore is pitted, then White Post Restorations.
I had them sleeve and rebuild front wheel cylinders for my 49 Studebaker dump truck, as they are not available new.... any where.
I rebuilt the MC in my Z 15 years ago, and it is leaking again, so getting ready to pull it and send it to White Post.
Old 10-01-2023, 06:27 AM
X66 714's Avatar
X66 714 X66 714 is offline
Here's the guy to go to. Mike Gibbons
https://www.brakeboosters.com/
Joe
Old 10-01-2023, 09:08 AM
Tuna Joe Tuna Joe is online now
Joe
Mike did an excellent job on my ‘69 Corvette MC
The Following User Says Thank You to Tuna Joe For This Useful Post:
X66 714 (10-01-2023)
Old 10-01-2023, 09:44 PM
Thanks guys, appreciated.
Old 10-01-2023, 10:56 PM
66BoxNova 66BoxNova is offline
Mike Gibbons , great work
Old 10-01-2023, 11:30 PM
67since67's Avatar
Mike Gibbons is top shelf!!
I've also had great results with Karp's Power Brake in Chino CA, and with White post. Last I knew Karp's uses SS sleeves while White Post uses brass, if it matters to you. - Bill W
Old 10-02-2023, 02:27 AM
All great info, thanks.
Old 10-02-2023, 10:10 PM
Jonesy's Avatar
Jonesy Jonesy is offline
Yes Mike Gibbons is awesome!! A guy that actually enjoys what he does!!
The Following User Says Thank You to Jonesy For This Useful Post:
mhm1966 (10-02-2023)
Old 10-04-2023, 04:13 PM
Had White Post do mine off the 69 Z and so far, everything is good.
