Old 09-16-2023, 12:53 AM
DAVE H DAVE H is offline
Default 1958 Corvette T10 4-speed
T10-1 case cast October 8th, 1957
Assembled December 5th, 1957 (WM57-2)
T10-7A Tailhousing cast November 5th, 1957
Original '57-'58 no date sidecover
I believe the shifter is '59-'62
The linkage has 2 heim joints that work but should be swapped out for original style.
The original tailhousing is included and has been weld repaired at the 2 mounting holes, (needs drilled and tapped or heli coils) The reverse retaining pin hole has been welded and needs drilled and the weld blended. The last small weld is @ the very rear and needs ground down and blended. A T10-7A is currently installed and dated for a '59. All pretty simple if you have the time, patience and the eyes for it.
I have rebuilt it completely installing a new first gear, 4 synchros, 2 main bearings, small parts kit and gaskets.
My price reflects the work still needed if you want to change the tail. $2,700 or $2,500 w/o the shifter and accessories. Please p/m your questions. Sorry for the goofy pics 🤪 Dave
Attachments - The Supercar Registry 20230917_191559.jpg 20230915_195747.jpg 20230915_195724.jpg
Old 09-17-2023, 11:31 PM
Actually, once my dumb a$$ got the rods configured correctly, the heim joints are pretty slick so I'll leave 'em.
Old 09-17-2023, 11:34 PM
Better pic of the linkage.
