Old 09-08-2023, 09:54 PM
napa68's Avatar
napa68 napa68 is offline
Default SOLD! 2020 ATC Quest 305 Aluminum Enclosed / Race Trailer
2020 ATC Quest 305 28' Enclosed Car / Race Trailer
Always stored indoors, always stored in winter. Excellent fit and finish. 6000lb spread Dexter axles. Approximately 9000 miles. New tires, new battery, and bearings repacked summer of 2023.
Below, are the specs for this CH305 ATC trailer
-8.5 X 28 Enclosed Aluminum Frame Trailer
-Finished Interior Floor, Walls, Cabinets
-Straight Upper and Lower Aluminum Cabinets black
-White Aluminum Walls and Ceiling Interior
-Black Coin Flooring
-120 volt 50 amp Electric Package, 3 interior outlets, 1 exterior GFI outlet.
-12 volt LED Interior, and Exterior Lights
-12 Volt Battery in lower cabinet, Electric has built in 60 amp converter charger.
-Screw-less Exterior WHITE .030
-One Piece Aluminum Roof
-16 inch On Center Framing, Walls, Floor, and Roof
-ATC Best Full Perimeter Framing
-Spread Axle Design- 2 , 6000 lb Dexter Axles
-7 ft. Interior Height
-Triple Tube Extended Tongue, 2 5/16 coupler.
-Ramp Door on back, Beavertail Floor to load Cars.
-36 X 78 Curb Side Door with FMVSS RV Latch , and Slide Out Step
-Stainless Steel Paddle Latches on Ramp Door
-1 Roof Vent Braced and Prewired for installation of Future AC
-2- 12 Volt LED Scene Lights curbside exterior.
-5- 5,000 lb. D rings for tying a vehicle down.
-Exterior Front of Trailer Stainless Steel Front and Top Radius, Cast Aluminum Corners.
-Aluminum Rims 6 Bolt with ST235/80R-16 Radial Tires
For more information or if you'd like to chat........
shop (715) 385-3700
cell (262) 844-5218
Tim
dykstra (09-09-2023)
