Old 09-06-2023, 04:02 AM
427.060 427.060 is offline
Default Bumper Jack Base Question
I am trying to figure out what these two jack bases are for. The only markings I see are a U on both. The holes for the jack are different. One has 2 round holes in it. The other has none. Any info will be appreciated.
Thank you, James
1968 Beaumont SD396
Attachments - The Supercar Registry 20230905_225116_resized.jpg 20230905_225102_resized.jpg 20230905_225033_resized.jpg 20230905_225015_resized.jpg
Old 09-06-2023, 07:30 AM
Canuck's Avatar
Canuck Canuck is offline
GM used several different Jack suppliers through the large 60’s and 70’s. I just did some research to get a correct Jack for my 68 Z28, Los car with a 4-68 build. Cars assembled at the Los plant mostly got square shaft jacks made by Walker Manufacturing. Norwood cars got trapezoid shafts like the one your base has. There is a third shaft, a cast iron with a T shaped shaft. I believe the U stands for Universal Manufacturing. The bases could be used accross all car lines with the length and hook being the difference.
www.vancouverclassiccars.com
Old 09-06-2023, 05:50 PM
Thank you for the info. I looked on eBay for bases like these but that wasn't much help.
James
1968 Beaumont SD396
Old 09-06-2023, 07:21 PM
nova7579's Avatar
nova7579 nova7579 is offline
The hole where the jack sets in looks bigger on the one than the other. The bigger hole is for the full size GM cars 1970 and later. The small hole would be for the intermediate GM cars 1970 and later.
ThanX
Brian
The Following User Says Thank You to nova7579 For This Useful Post:
Steve Shauger (09-07-2023)
Old 09-07-2023, 03:53 AM
Jonesy's Avatar
Jonesy Jonesy is offline
I dont think I have ever seen a T shaped shaft in any year Camaro from the factory.
Square for 67-69 Van Nuys and Trapezoid for all other Camaros thru 81.
Old 09-07-2023, 04:36 AM
Thanks for the additional info
1968 Beaumont SD396
