Old 07-31-2023, 04:58 AM
GotGrunt's Avatar
GotGrunt GotGrunt is offline
Default 1966 Chevelle 10-bolt rear
1966 Chevelle 10-bolt rear, casting number 3875744 N, CE code 3.08 posi. The rear is in extremely good condition and has poly bushings & moroso extended studs installed. It comes with the parking brake cables & a full set of lug nuts. $500 picked up from Long Island, NY
Attachments - The Supercar Registry IMG_0227.jpg IMG_0226.jpg IMG_0225.jpg IMG_0223.jpg
Old 07-31-2023, 12:57 PM
big gear head's Avatar
Did someone swap the spring perches?
Freddie
Old 07-31-2023, 01:34 PM
GotGrunt's Avatar
Yes, it looks like the spring perches are the 1967-72 style. You would just have to use the later style springs.
Old 07-31-2023, 03:27 PM
OK. I didn't know if they had been swapped or if this was something that I hadn't seen before on a '66.
Freddie
Old 07-31-2023, 03:41 PM
GotGrunt's Avatar
It looks completely factory so at first I thought this was a 67 rear until I decoded it. I do have another “nothing special” 1964-66 10 bolt I can include at asking price (has the correct bolt in spring perches) if anyone wants to put this back to original.
Old 07-31-2023, 08:29 PM
Too Many Projects's Avatar
No need to change springs. The lower end of the '66 is the same as '67-'72. It's the upper end that is the open style.
Mitch
1970 Chevelle SS
1966 Chevelle SS
1967 Camaro ss/rs
GotGrunt (07-31-2023)
Old 07-31-2023, 09:13 PM
GotGrunt's Avatar
Even better
