Old 06-22-2023, 07:17 PM
Default 1970/71 Camaro Hurst 3138 Shifter Questions......
Questions on 1970/71 Camaro Hurst 3138 Shifters.....
1 Stamped #'s 0500411C & 0400422P. Is this 1970, 5th Month
& 1970, 4th Month ?????
_______________________________________
2 Can these dates be SEEN when installed ? If so are they a
Judging Point at Camaro Natl's LEGENDS
__________________________________________
3 I'm thinking Vast Majority of 3138 Shifters in 1970 Camaro
were Silver ZINC Plated.....and Gray Phosphate started in 1971.
ONLY if you KNOW you have Born With Shifter, Please state
your Model Year, Build Date and Shifter Plating Finish
_____________________________________________
4 Are there aftermarket Shifter Rods and Side Cover Arms
available for these Hurst/Muncie Shifters Brand/Part # ??
__________________________________________________
5) Where can I learn, see diagram of how the Handle Inserts
into Shifter with the Rubber/Metal piece
__________________________________________________ ____
6 Current selling value of rebuilt 3138 Hurst and Rechromed
Handle without Rods OR Complete WITH Rods
__________________________________________________ ______
7 Are the Black Plastic Bushings that Isolate End of Rod(s)
where they attach at Shifter (Arms) the Only Correct Parts to
Use ? What goes at Transmission End of Shifter Arm ??
Chuck Sharin
[email protected]
69 Camaro COPO "recreation"
