Old 06-10-2023, 11:44 PM
RALLY RALLY is offline
Default Used front & rear factory take off shocks complete set 3192826-3192829 Delco
Selling a complete used set of factory Delco Remy front and rear shock absorbers taken off a 1971 Nova. These shocks were installed at the factory. Front shocks 3192826- Rear shocks 3192829. Shocks have flash rust on them and some factory undercoating over spray. No holes at all. Front shocks have some slight rust pitting at the top of the shafts which will not harm anything. I cleaned shocks with oil and scotch brite. Still retain some of there original light blue paint. Shocks do not leak. Shake and you can hear the oil inside. Shocks collapse easily with some resistance extending up. May need a rebuild, you be the judge. Shocks all have the visible factory part number stamped on the lower shock bodies. Julian date codes stamped read fronts 114-71 Julian date- Rear Julian dates stamped 169-71. Again these were removed from a 1971 Nova. These shocks were not used on the F41 suspension. They are the for the Mono leaf rear suspension. 100.00 dollars plus shipping buys them. If interested, send me a PM with your email address and i will send pictures. Shocks fit 68-74 Small and Big Block Novas and the 69 Camaro only fit the front shocks only.
