Old 06-09-2023, 10:27 PM
Too Many Projects's Avatar
Default EDB 30174 carrier
I have a 12 bolt A body axle for my Chevelle and took the carrier out several years ago to change the ratio. I'm having a buddy reassemble it tomorrow and looked it over to make certain I had all the parts. When I saw the carrier number and the small window, it triggered some vibrations in the cob webs about this style used on the COPO's. After doing a search and reading past information it unfortunately, doesn't appear to be one. Still a good carrier for some fun and abuse.
I couldn't find a stamp on the ring gear but the inspection stamp is the same as the pinion.
Mitch
1970 Chevelle SS
1966 Chevelle SS
1967 Camaro ss/rs
Old 06-11-2023, 04:02 PM
big gear head's Avatar
That one has the standard 200 pound preload springs and thin plates. I've seen a thousand of these Eaton units and I've only seen one 30174 that didn't have the square hole.
Freddie
Too Many Projects (06-16-2023)
Old 06-12-2023, 07:44 PM
Thanks Freddie, I figured it wasn't anything special but a guy can always hope, eh...
My buddy put it back together with the original shims and the backlash checked good, so ready to go, well almost, needs shoes and wheel cylinders...
I bought new axle bearings at NAPA and they are .001-2 smaller diameter and fit loose in the tube. He wasn't happy with that, so we put the old ones back, that really weren't bad, I was going to replace as a cautionary measure.
I kept telling him it was only going to go a couple miles anyway.... 1/4 mile at a time....
Mitch
1970 Chevelle SS
1966 Chevelle SS
1967 Camaro ss/rs
Zman1969 (06-16-2023)
Old 06-16-2023, 12:52 PM
Zman1969 Zman1969 is offline
I have 2 at the moment and both are big windows
69 RS/Z 302 VE3 Daytona
69 Chevelle SS 396 375
69 T/A clone LS6/6 speed
90 Formula 350
The Following User Says Thank You to Zman1969 For This Useful Post:
big gear head (06-17-2023)
Old 06-17-2023, 01:40 AM
A few years ago I would have told you that all of the 174 cases had the small square window.
Freddie
