Old 06-05-2023, 05:19 PM
chads454Ls6 chads454Ls6 is offline
Default Tilt column Identification
I know this is an A-body column, but was trying to figure out was it out of a Chevelle? It has tilt and cruise so that is why I would like to know exactly. It measures 34 inches shaft to shaft, it is an automatic floor shift. It has the numbers on the lower part that read B2659S. Is that 265th day of 69? TIA.
Attachments - The Supercar Registry FAB410DD-896E-4849-A85A-C1F570CC0566.jpeg CCB2EE9C-91B6-4BA3-8771-2641EA3986D9.jpeg B3B5B397-E949-488E-AD11-692DF7F44B39.jpeg 669826D8-66F4-4567-9EFD-613D2F8D2665.jpeg
Old 06-05-2023, 06:46 PM
X66 714's Avatar
X66 714 X66 714 is offline
Where it says lock is it rectangular or oval, like a pill? Rectangular is 69 only. Looks like it has Chevrolet knobs...Joe
Old 06-05-2023, 08:31 PM
I believe it is “rectangular” but I will check when I get home.
Old 06-06-2023, 03:06 AM
DWR DWR is offline
The knobs on 70 and earlier tilt levers were smooth hard plastic. 71 and later were textured rubber. Same goes for column shift levers and non cruise signal lever knobs.
Old 06-06-2023, 03:41 AM
Rectangular. The tilt knob does not look original to me.
The Following User Says Thank You to chads454Ls6 For This Useful Post:
X66 714 (06-06-2023)
Old 06-06-2023, 05:06 AM
John Brown's Avatar
FWIW, 69 used an E coded key.
John Brown
