Old 03-31-2023, 04:16 AM
Default Replacing a Heater core in a 1979 Trans Am
Any input on replacing a heater core in a 1979 Trans Am with A/C and a 301 Pontiac engine as far as a supplier for the replacement part and tricks of the trade to get the old one out with out taking the whole interior and steering column out? The Saga continues with (My) Old cars. Bill
Old 03-31-2023, 03:58 PM
ronzz572 ronzz572 is offline
This will require lowering the right inner fender well to access the firewall side hvac box fasteners and heater hose connections. I don't think you will need to remove the dash. The heater hvac box should come out at least with removing the glove box and pulling out the passenger side of the dash.
1970 L78 camaro Cortez silver ralley sport under restoration
1970 L78 camaro cranberry red standard black interior original drivetrain.
The Following User Says Thank You to ronzz572 For This Useful Post:
Big Block Bill (03-31-2023)
Old 04-01-2023, 03:04 PM
L72Biscayne L72Biscayne is offline
Find a good radiator shop and have a new core put on the original tanks. Has far as tricks. It's pretty straight forward , jack up right side take wheel house out and remove glove box and pull back your rug to put down towel to soak up any anti freeze that spills. I just had mine re cored in my 70 Z which is pretty much the same car.
1970 Z28 Citrus green CW 3:73 1970 Ls6 Cy 3:31 14K miles 1968 Biscayne L72 M22 952 actual miles. 1966 Biscayne L72 3:73 1966 Chevelle L78 M22 4:56
Old 04-01-2023, 04:11 PM
I appreciate the input, but this is an A/C Car with a Console. I've replaced many a Camaro and Chevelle's heater core before but not in an A/C car with a Console. It looks to be a little more complicated than that. I don't want to disturb the dash and console if I don't have to (44 year old Plastic Parts and all). I've started on it yesterday and have the right wheel well out, the glove box out and onto the duct work and heater box on Monday. Bill
Old 04-01-2023, 09:44 PM
Too Many Projects's Avatar
If the stars are aligned for you, the console may not need to be disturbed. There should be plastic ducts on the outlet of the heater box that can be removed for more clearance. Never done a Firebird specifically, but done plenty of others and there is usually a way to wiggle that box out or rotated enough in place to extract the core. You've worked on enough cars to recognize where that can happen once you are in it.
And L72 is right about getting yours repaired or re-cored. Most of the aftermarket stuff is ill fitting and cheaply made.
Mitch
1970 Chevelle SS
1966 Chevelle SS
1967 Camaro ss/rs
Big Block Bill (04-02-2023)
