Go Back   The Supercar Registry > General Discussion > Ford-Mercury
Old 02-25-2023, 10:58 PM
roadster roadster is offline
Default 63 R code convertible
Have seen this car at couple local shows , long time ownership , father and son have been together at both shows .The dad purchased car when was almost new if I recall . These pics from October 2022 . Sign says total 63 427 convertible production ( both single 4 barrel and R code dual quad) was 411 . Asked them about 63 1/2 and learned that only applied to fastbacks .
The Following 13 Users Say Thank You to roadster For This Useful Post:
1967 4K (02-26-2023), 427TJ (02-26-2023), 67 Nova Boy (02-26-2023), 69M22Z (02-25-2023), Big Block Bill (02-26-2023), L78_Nova (02-26-2023), ls6owner (02-26-2023), L_e_e (02-25-2023), olredalert (02-25-2023), PeteLeathersac (02-25-2023), RPOLS3 (02-26-2023), scuncio (02-26-2023), Tenney (02-28-2023)
Attachments - The Supercar Registry FCEF5575-C9B9-431E-BA4D-CF8206CB4FBD.jpg F8848D5C-585E-40C4-8C65-7E654AF3A7F1.jpg EAFBE5B3-6D78-4894-A36C-C53E7D834328.jpg A049F6D9-EB5A-4871-A1D7-70335F0A81A5.jpg
Old 02-26-2023, 03:52 AM
427TJ's Avatar
427TJ 427TJ is offline
Always loved those repurposed and modified '56 Mercury wheelcovers they used on the 427 Galaxies in '63 and '64.
Old 02-26-2023, 03:01 PM
----This is just a real beauty and rare as well, but boy would it look better with correct whitewalls!....Bill S
The Following 4 Users Say Thank You to olredalert For This Useful Post:
427TJ (02-26-2023), 67since67 (02-26-2023), Big Block Bill (02-27-2023), Bill Pritchard (02-27-2023)
Old 02-27-2023, 12:56 AM
tom406 tom406 is offline
1963-1/2 does typically refer to the Fastback 2dr HT, which was a midyear introduction of a new lower and sleeker roofline that utilized the windshield from the convertible instead of the 2 and 4dr sedans. Technically the 427 engine option was a midyear change as well, supplanting the 406 around January 1963.
The Following 3 Users Say Thank You to tom406 For This Useful Post:
Big Block Bill (02-28-2023), olredalert (02-27-2023), roadster (02-27-2023)
Old 02-27-2023, 03:04 PM
We’re any of the 63 406 cars multi-carb? Seems like remember reading about the early 63 406 cars but don’t recall seeing any .
Old 02-27-2023, 03:22 PM
----Somebody may correct me but I believe the 406 had triple Holleys.....Bill S
67since67 (02-27-2023)
Old 02-27-2023, 04:00 PM
They were definitely tri-power , my dad bought new 62 Ford with 406 and tri-power . Just not sure if 406 was available in any other configuration . He used to say maybe those 409 Chevys were fast on the drag strip but they could not hang with the Fords on the road . Looked into and apparently 406 available single 4 barrel or tri-power in both 62 and early 63 both were 11.4 to 1 compression .
The Following 2 Users Say Thank You to roadster For This Useful Post:
69M22Z (03-01-2023), olredalert (02-28-2023)
Old 02-28-2023, 02:31 AM
406 was introduced mid ‘62 and phased out mid ‘63. B-code 1x4bbl 385hp and G-code 3x2bbl 405hp versions were offered. The handful of ‘62 Lightweights got a special 2x4bbl version of the 406 that foreshadowed the later 2x4bbl R-code 427s. The single 4bbl 406 and 427 were primarily for NASCAR homologation (No multiple carbs) while the multiple carb versions were drag racing focused.
The Following 2 Users Say Thank You to tom406 For This Useful Post:
427TJ (02-28-2023), olredalert (02-28-2023)
Old 02-28-2023, 02:58 AM
62 406 tri-power transplant .
The Following 6 Users Say Thank You to roadster For This Useful Post:
69M22Z (03-01-2023), Big Block Bill (02-28-2023), L_e_e (02-28-2023), olredalert (02-28-2023), PeteLeathersac (02-28-2023), Tenney (02-28-2023)
