Old 02-07-2023, 07:35 PM
napa68's Avatar
napa68 napa68 is offline
Default Sun Temp Gauge Technical Help
Looking for a bit of troubleshooting guidance on my Sun blueline temp gauge.
Took the car apart in fall for an engine freshening. Gauge worked good then (reasonably accurate) with what I felt was an original sending unit.
Fast forward to this week. I get the car running, but the gauge is DOA. I have power going to the gauge, and the wire running from the gauge to the sender has continuity with no resistance of sort.
In short, are the gauges that fickle? I noticed the engine builder coated the sender in teflon paste. The sender measures about 13 ohms from base to terminal at room temp (63 degrees).
Tim
