Old 02-06-2023, 04:41 AM
AnthonyS's Avatar
AnthonyS AnthonyS is offline
Yenko Advertising Member
Default NOS GM cam 3965754 Duntov 30-30 SBC 302 327 L79 Z/28 off-road LT-1 Z28
Hi Gang,
I have another NOS camshaft here - the part number tag 3965754 is loose, but fell off under my custodianship. This, I believe, is the so-called 2nd design off road small block solid / mechanical lifter cam. Also has the 1973 up special off road parts announcement sticker common on the OTC HiPo parts...
There is the 55 cast number on it, which typically is one digit higher than the actual part number ending which is 54 here, and corroborates. This camshaft is also stamped 3975754 on the end too leaving little doubt to what it is. See photos.
I do believe it's an unused and genuine GM High Performance SBC Duntov 30-30 type camshaft. Not sure if it can cross with these other part numbers: 3849346 3965754 3863151 3972178.
Factory parkerizing still present and no wear on lobe tips - any crumbs visible are remnants of cardboard from the chaffing of decades in that tube.
See photos for condition.
700.00 PPFF plus shipping.
Thanks all,
Anthony
The Following User Says Thank You to AnthonyS For This Useful Post:
L78_Nova (02-06-2023)
Attachments - The Supercar Registry IMG_3411.jpg IMG_3410.jpg IMG_3409.jpg IMG_3408.jpg
