Old 02-01-2023, 05:01 AM
AnthonyS's Avatar
AnthonyS AnthonyS is offline
Yenko Advertising Member
Default complete take off 1969 Camaro under hood brake system
Hi Everyone, this is a special treat.
I have available a complete under hood brake system off a HiPo 1969 Camaro.
This is a fairly recent take off from a car being "restored".
It includes everything shown in the photos still together and as assembled by GM 50+ years ago - I have no reason to believe any of this has been apart or rebuilt or serviced previously beyond the fact that the lid just says "use delco brake fluid" & "service with delco parts" and doesn't mention J1703... also, there's one bail wire MIA, but that's an easy piece of the puzzle!
Typical California rust free and dry parts - no evidence that the master ever leaked.
This is the way you want to find these parts!
All hoses and lines still attached, but cut off - the threads & connections have all been preserved. Even includes the original 3 dot vacuum check valve although it's dry. Hose and clip, and cut off tube included as shown attesting to originality of the set up.
9204 Booster is nice and pit free and dated 310 - both stamps nearly completely all the tab, which is not often the case - very clear stampings. Upside down Delco Moraine stamp present - some original finish present still.
5468309 master cylinder is cast dated 300, looks like - and I don't see a stamped date. The US pad stamp is nice, and clear too.
Distribution block & hold off valve both present as shown and likely original to this system. I did not scuff them looking for markings.
The rod is stamped F9 of course and the end has the vendor mark / stamp as shown, the plastic boot is also original with the T embossed.
This set up is a prime candidate for a sympathetic restoration / rebuild to preserve the original finishes or patina. While this was off a running car I'm told, everything should certainly be gone through before installation.
Not a pieced together system here - completely original, again, this is what you want.
Not much more can be said about this, and many photos below to give a full picture.
These don't appear often anymore.
2000.00 PPG plus shipping and insurance if wanted.
If you need rebuilt 5463633 calipers dated for this set up, ping me and I'll certainly work a deal for the buyer.
Cheers all,
Anthony
The Following User Says Thank You to AnthonyS For This Useful Post:
dustinm (02-01-2023)
Attachments - The Supercar Registry IMG_5695.jpg IMG_5550.jpg IMG_5549.jpg IMG_5548.jpg
