Old 01-19-2023, 12:40 AM
JoePientaJr JoePientaJr is offline
Default Re: 3946052 Block - Possible Can-Am ?
I am curious if anyone here has seen a 3946052 engine block like this one. I’m fairly certain this is not a winter foundry block. It has two #2 ink stampings on the left and right side of the front of the block. (Almost like it’s a test block #2) Also it has 19639-D on the front suffix pad location. Thanks in advance, any help would be appreciated.
~ Joe
The Following User Says Thank You to JoePientaJr For This Useful Post:
Carleen (01-19-2023)
Attachments - The Supercar Registry IMG_5776.jpg IMG_5775.jpg IMG_5774.jpg IMG_5773.jpg
Old 01-19-2023, 05:44 AM
COPO COPO is offline
What is the bore diameter?
Old 01-22-2023, 05:57 PM
William William is offline
IMHO a 'true' Can-Am aluminum bb casting does not have provision for a mechanical fuel pump.
Is there a casting date on the LH side near the motor mount?
Old 01-23-2023, 10:06 PM
Sorry guys I had to take an unexpected trip out of state. When I return I’ll answer the questions. Re: a date on the block… I looked all over it and couldn’t find a date but I will look some more.
~ Joe
Old 01-20-2024, 08:25 PM
The bore is 4.250
I also see 19639-D is stamped into the corner lip for the oil pan.
~ Joe
Old 01-21-2024, 02:40 PM
JoeC JoeC is offline
Don Yenko took over the production of the ZL-1 block in about 1974
There were still some teams running the ZL-1 block in SCCA where the Can Am block was not allowed
Old 01-21-2024, 03:43 PM
bergy's Avatar
bergy bergy is offline
Need pictures of the entire block. Front, rear, top & bottom. The part number appears to be located on the housing cores. If that’s the case, the actual mold may not even be for that part number. Housing cores can be common to different applications.
Old 01-21-2024, 06:50 PM
Carleen's Avatar
Carleen Carleen is offline
It might be a block from 1997
Old 01-22-2024, 04:11 AM
Sorry I know these are horrible photos but they are all I have until spring.
~ Joe
Old 03-26-2024, 12:53 PM
Lampmane2
Guest
Posts: n/a
Wow! That's nice
