Old 01-05-2023, 10:26 PM
whitetop whitetop is offline
Default Sun Gauge Stuff
1. NOS Sun sender wts-125 for the Blue or Greenline 2 5/8 wts 260 water temp gauges. This is for the Chrysler application but will fit GM with the Sun bushing which I will supply. The gauges were all identical just the sender was different due to intake hole size. Ohns/Resistance was all identical whether GM, Ford, AMC or Chrysler.
$250 shipped or bo.
Super nice SST. I have no idea if it works but the needle bounces around freely as it should. Dated 1969. 12 volt negative ground. Now the bad part. It is for a 4 cylinder 12 volt. Run as a display piece in your car or send to Williamson's to convert to 8 cylinder. Chrome is like new no cracks
$150 shipped or bo
Sun Blueline Oil pressure. Mitght be NOS or rarely used.The narrower part of the brass fitting was cut off for some reason. The threads left are perfect and long enough so and you can buy brass fitings to step down to correct size. I put a rubber hose to a air compressor and gauge works fine
$130 shipped or bo
Old 01-06-2023, 12:24 AM
DW31S's Avatar
DW31S DW31S is offline
PM sent
