Old 12-27-2022, 09:54 PM
RamAirBirds's Avatar
RamAirBirds RamAirBirds is offline
Default 69 Trans Am Correct Coil Springs
I know this has been discussed and probably hashed out before but sometimes hard to find what you know you've seen before on these threads.
What is the the MOOG Part # for the correct Coil Spring for the 1969 Trans Am
Likewise what would be used for a 1969 Non Air Firebird 400
Help is greatly appreciated.
RA
Old 12-27-2022, 11:09 PM
If you go for the Moog springs make sure you force test them at the installed height. I just checked a set of 5278's and they were about 130 lbs light at the 11 inch installed height. Can't trust anything anymore it seems.
Owned since 1978 - First Car
Old 12-27-2022, 11:38 PM
Thanks for that heads up.
Im starting to think / remember that the front coils are the same for a Firebird 400 and a Trans Am.
The Rear Leafs are for sure Trans Am only in that they are only 3 leaf. Thus the lower rear ride height.
Comments?
Old 12-28-2022, 12:44 AM
tjs44 tjs44 is offline
T/A hood is heavier.Tom
