Old 11-16-2022, 06:10 PM
msclassiccars's Avatar
msclassiccars msclassiccars is offline
Default 5.9L Cummins Diesel 12 Valve Turbocharged Custom Engine and Stand
Selling with NO RESERVE on Bring a Trailer (Click to view auction link)
Watch this showcase video
**THIS ENGINE AND STAND IS CURRENTLY SELLING LIVE ON A BRING-A-TRAILER ONLINE AUCTION WITH “NO RESERVE”. YES, NO RESERVE! THE AUCTION ENDS ON TUESDAY NOVEMBER 22 @6:35PM. IF YOU’RE INTERESTED IN PURCHASING PLEASE REGISTER TO BID DIRECTLY WITH BRING-A-TRAILER. IT’S A QUICK AND SIMPLE PROCESS. PLEASE CALL WITH ANY QUSTIONS. THANK YOU.**
This 5.9L Cummins Diesel 12 Valve Turbocharged Custom Engine and Stand is the ultimate combination. This International block is from the 1994-1998 generation which is considered the best by enthusiasts because it’s far as performance potential goes; it doesn’t get any better than the mechanical P7100 equipped versions of the 12-valve Cummins. They’re simple, rock-solid reliable and can easily tick off a half a million miles if properly maintained. It was originally built in 2018 with intentions of putting it into a high-end classic pickup. The stand was made for the engine while the pickup was being built. Both the engine and stand were professionally built by Marco Martins of Bad Apple Customs. Tons of hours and thousands of dollars were invested. With all the modifications and a proper tune it’s estimated to have 800+HP. MS CLASSIC CARS purchased the package in May of 2022 where it’s been admired on display.
Listed below are the details on the engine.
International Block from 1994-1998 generation.
Machine work completed by Simplex Machine in Providence, RI.
Completely rebuilt with stock parts including bottom end, crank, rods and pistons.
Custom ground race camshaft.
O-ring cut cylinder head.
Hamilton valve springs.
ARP head studs.
Scheid Diesel billet aluminum side cover part #1054033rQV-2.
Scheid Diesel billet aluminum timing cover part #10540351.
Wild Diesel billet aluminum valve cover.
Keating billet aluminum fuel pump cover.
Factory black oil pan part #3949338.
Borg Warner - Phatshaft S366 Turbo part #66183. Model: 2nd Gen. Serial #06483 Date: 05-22-2017.
5x20 Industrial injection injectors.
Sheid Diesel SS Injectior lines.
Seth Farrell 13mm injection pump.
Scheid Diesel air intake part #1054032012.
Horschel Motorsports performance harmonic fluid damper.
Fleece coolant bypass with braided line.
Electric water pump.
Power steering pump.
Woodward solenoid.
Oil pressure gauge.
Stainless Diesel polished exhaust manifold.
Listed below are the details on the stand.
Custom steel engine cart that was painted blue.
Removable handle that secures to the cart.
GTW “Specter” 12x7 black and stainless wheels.
Kenda Pro Tour 205-35-12 tires.
Marc Schiliro
MS CLASSIC CARS
www.msclassiccars.com
Tags
cummins, diesel, engine
