Old 10-05-2022, 04:05 PM
ALLZS ALLZS is offline
Default Smog pump date code
I have a pump with 13881Z stamped on it is this a 68 pump also I have seen with a S at the end of the date code but not a Z
Old 10-05-2022, 04:14 PM
X66 714's Avatar
X66 714 X66 714 is offline
I found this on CRG....Joe
The last digit is the configuration code of the pump. The 67 pumps are coded A and C. (67 Corvette pumps are coded P and are unique to that application.) The 68 pumps with a pressure relief valve installed in the pump were coded Y. Non-pressure relief valve 68 pumps were coded Z. 69 and later pumps (without a pressure relief valve) were coded S.
The Following 3 Users Say Thank You to X66 714 For This Useful Post:
69M22Z (10-07-2022), Bill Pritchard (10-06-2022), Ralph Spears (10-05-2022)
Old 10-05-2022, 05:59 PM
ok thanks so it looks like a 68 pump without the reliel valve, did a certain model use the with or with out on the valve
Old 10-06-2022, 01:20 PM
X66 714's Avatar
This is also from CRG....Joe
The 68 pumps used on Z28's and big blocks had a pressure relief valve installed on the side of the pump. The Z28 relief valve has a green plastic plug and the 396 relief valve has a black plastic plug The 68 pumps for L6, 327, and 350 engines and all 69-and-later pumps did not have the pressure relief valve on the pump; it was incorporated into the diverter valve.
The Following 2 Users Say Thank You to X66 714 For This Useful Post:
Bill Pritchard (10-06-2022), mhm1966 (10-06-2022)
Old 10-07-2022, 01:22 AM
Good info thanks
The Following User Says Thank You to ALLZS For This Useful Post:
X66 714 (10-07-2022)
