Old 08-22-2022, 01:47 PM
bergy's Avatar
bergy bergy is offline
Default Correct part number for 67 BB motor mounts?
Having trouble finding the correct 67 BB Camaro motor mount part number. I have #701s, but that may not be correct?
Thanks
Old 08-24-2022, 08:02 PM
Chuck_Burg's Avatar
3912598
The Following User Says Thank You to Chuck_Burg For This Useful Post:
bergy (08-25-2022)
Old 08-25-2022, 05:21 PM
Chuck_Burg's Avatar
Not sure if that's what you're looking for, these are the frame mounts..
Old 08-25-2022, 05:48 PM
bergy's Avatar
Thanks Chuck. I have the original frame mounts. Wanted the motor Side mounts #. I found a set.
Old 08-25-2022, 06:08 PM
You found a set?,can you relay the part#'s?
Old 08-25-2022, 06:40 PM
bergy's Avatar
I haven’t received them yet. Non-locking early take offs. I believe 3886466
Old 08-26-2022, 03:29 PM
3886466 is the part number shown for 67 Camaro 396 in the July 1967 parts book revision. Those are the ones without an affixed nut on either side.
The 67 Camaro AIM does not show mounts in L35/L78 sections, which means they should install same as the 283 small block V8 mounts as shown in Section 6. Section 6 shows mounts without any affixed nuts and shows a loose washer and nut being used. So 3886466 is most likely assembly line correct.
Trivia - 65-67 Chevelle 396 assembly line mounts were the exact same design mount except with an affixed nut on the rear facing side, so they are left-right specific. (It is all but impossible to find a good set of those.) The 67 Chevelle part numbers were 3886467 and 3886468. But the initial service replacement part was 3886466 for both sides (supply your own nut, I guess).
Jeff Helms
65 Z16 Survivor
65 Z16 drag car
66 Chevelle L78 unrestored
67 Chevelle L78 unrestored
67 Camaro SS350 Survivor
The Following 5 Users Say Thank You to jeffschevelle For This Useful Post:
67since67 (08-26-2022), bergy (08-26-2022), Chuck_Burg (08-27-2022), Steve Shauger (08-26-2022), X66 714 (08-26-2022)
