Old 08-17-2022, 07:38 PM
William William is offline
Default Caveat Emptor...a mess
https://www.ebay.com/itm/325308387935
124379L530175
From the ad:
"I traveled to Colorado and purchased this car in 2007 after having gone over it with a fine-tooth comb to make sure it was a true Z/28. I wanted it and bought this car is a driver. It is an Orange County car, so it does not have the X-code like the Ohio cars. You must look to the components to judge the authenticity."
Let's do that.
L530175 was final assembled at Van Nuys on or about June 19, 1969.
Rear axle stamped BU1022, October 22nd. No casting date so could be 1967 or 1968. Date is way off; not original to the car.
Trans is stamped P9B15A, no VIN shown. No proof it is original to the car.
Engine is said to be V1122DZ, no pic. Ad states it is a 3970010 casting. Earliest known 010 casting is April 4, 1969 so the block has to be a re-stamp. Block is also stamped 19S738159; consignor states "S=Signow service plant, 738159 = rebuild ser. # post model production." NO idea where he came up with that; 19S738159 is a 1969 Corvette VIN.
Based on the info posted, none of the info supplied established "it was a true Z/28. "
The Following 11 Users Say Thank You to William For This Useful Post:
67BelAir427 (08-17-2022), bergy (08-18-2022), Big Block Bill (08-18-2022), Crush (08-17-2022), dykstra (08-17-2022), McCune (08-17-2022), napa68 (08-17-2022), olredalert (08-17-2022), PeteLeathersac (08-18-2022), Steve Shauger (08-17-2022), Z282NV (08-18-2022)
Old 08-17-2022, 09:48 PM
McCune McCune is offline
I see spider webs. Pretty sure that means it is real!
