Old 07-22-2022, 02:00 AM
427.060 427.060 is offline
Default 7 Blade Fans Application And Value
I have been digging through some of the parts I have and found two 7 blade fans. I am trying to find out what they are for and what they are worth. The first is numbered 3931002 and dated F68. The second is 3937779 and dated G68. Both have clutches but I'm not sure if they are the correct ones.
Thank you, James
1968 Beaumont SD396
Attachments - The Supercar Registry IMG_0771.JPG IMG_0770.JPG IMG_0769.JPG IMG_0768.JPG
Old 07-22-2022, 03:24 AM
Rsconv68 Rsconv68 is offline
I found this on a Corvette forum. Hope it helps.
It's a big block fan & clutch, but not for a Corvette. This is what Joe Lucia (heap big Corvette parts authority) says about that fan on the NCRS site:
"The GM #3931002 fan blade assembly was never used on a Corvette. It is a 7 blade fan originally used on 1968 full size Chevrolet passenger cars with air conditioning and 396 or 427 engines. It was also used on some full size Buicks and Cadillacs of the period. GM #3931002 was discontinued from SERVICE in October, 1986."
Old 07-24-2022, 01:34 AM
Pictures added. The red one is the 3937779 one.
1968 Beaumont SD396
Old 07-24-2022, 02:39 AM
dvss1 dvss1 is offline
The 779 fan was used on early built 69 cars and pickup trucks with air conditioning. I believe up to November 68.
Old 07-24-2022, 04:01 AM
X66 714's Avatar
X66 714 X66 714 is offline
Here's some 1st gen Camaro info on fans & clutches....Joe
http://www.camaros.org/coolingsystems.shtml#fan
Old 07-24-2022, 05:35 AM
That info helps. Thanks for the responses.
1968 Beaumont SD396
The Following User Says Thank You to 427.060 For This Useful Post:
X66 714 (07-24-2022)
